Album Artist, Album _Artist.
Hi.
Quick question before i start sorting the metadata on some of my albums.
When i browse my music using the Naim app under the "Artist" tab then say press "D" not all of the albums surname beginning with "D" are showing.
When i look at the metadata [U]some[/U] of my albums have more more than one sort field, some have no sort field (mainly downloads).
Artist Sort
ARTIST_SORT
Album Artist Sort
ALBUM_ARTIST_SORT.
When i edit the metadata do i delete "ARTIST_SORT" and "ALBUM_ARTIST_SORT" or do i add them to the albums that do not have them. Am i right in thinking these duel fields are the cause of my problems.
Naim Uniti Nova.
Qnap HS 251 nas.
Asset 6.2.
Edward
Re: Album Artist, Album _Artist.
There is a configuration option to ignore the sort tag:
The Artist & Album Handling has 3 modes (examples using The Beetles):
Smart: this mode keeps the artist text as The Beetles, yet sorts the artist under 'B'
Value, The: places the on the end, for example Beetles, The
Leave as is: does not adjust the displayed value or sorted position
Trying PerfectTUNES will speed up sort management, it can show inconsistent sort tags.
Not sure if this is correct to post my query as a reply here, if notI apologise
I have noticed recently what appears to be a change to my Asset listings on the client devices.
I always use Album Artist as the main tag for listing. Ths works fine for me.
I am now noticing that some artists names appear within their different lists - e.g. Link Wray appears in both L and W (all albums in both).
However Warren Zevon only appears in W and not Z.
As far as I know, I have not set the AlbumArtistSort or ArtistSort tags. I have Artist Sort Handling set to the default of Display n Sort and Non-Sort Locations for all instances of Asset.
As I say, I have only recently noticed this.
Has something changed in an update to Asset? I updated to version 6.3 in December 2019. Or have I started ding something wrong, or has this always been the case and I have not noticed before?
TIA for any advice.
These tracks will have no artist sort.
One or all of these tracks has the artist sort set as 'Wray, Link'
Thanks Spoon I will checck the tags again.
Would it be simpler than looking for all Artist Sort tags, to set Artist Sort Handling to ignore?
I have no need tosort in that way.
I set Artist Sort Handling to ignore and everything is now as I wish...
EXCEPT
even though 'The' Artist & Album Handling is set to Smart, all artists appear in T listing, e.g. Tne Beetles no longer appear in B but now in T no what I require
Does the smart handling make use of the Sort tags in some way?
I will now try setting the 'The' Artist & Album Handling tag to [value], The which hopefully will mean that The Beetles appear in B, albeit listed as Beetles, The.
Ths isrobably not a major issue for me.
Yes this option requires sorting not to be disabled as it relies on it.
Thanks Spoon
Setting the 'The' Artist & Album Handling tag to [value] gives the required result.
