<no CD drive found>
I have a win10-machine, I have googled some, and a lot of people seem to have problems with CD/DVD-drives in win10 diesapperaing. Mine work in a way, but I cannot see them in dBpoweramp. The are visible in the explorer, and they are visible in EAC, but not in dbpoweramp (and not in J river media center, if that helps).
A realted question, can you export the medtadata from dbpoweramp to eac-rips easily? I have heard good things about the meta-data-capability of dbpoweramp, and that is my main reason for trying it. I will probably use EAC for the actual ripping.
Re: <no CD drive found>
You would be best trying a cheap USB cd drive. It is not possible to export the metadata.
[QUOTE=Spoon;181844]You would be best trying a cheap USB cd drive. It is not possible to export the metadata.[/QUOTE]
I am not giving up my plextor premiums for a cheap usb drive :) I tried installing win7 on the machine, with the same hardware, it works there.
