Problem with key disk
  • apple185
    • Oct 2020
    Hello. I'm using an external ODD and the model is LG's gp62nw60
    And i also using EAC.
    Despite the ODD equipment released in 2018, offset detection using Keydisk is not possible.
    The disks I used are The Beatles 1 and Daft Punk's Discovery.
    Is there anything else I missed other than using the disk in the Key Disks list?
    It's very confusing. I believe someone can help.
  • Wayne
    • Aug 2002
    • 1252
    Re: Problem with key disk
    Have you used these CDs before to configure a drive? They could be a different pressing to that in the AccurateRip DB.
      • 5744
      just keep trying with popular CDs. It can sometimes take 10 or 15 disks before it configures. And sometimes only one.
      • apple185
        • Oct 2020
        Thank you for your reply
        But i'm gived up.
        I will find better software than EAC
          • 5744
          But i'm gived up.
          You should look at the top of this page. dbpoweramp, the forum you are on, is--in my opinion--a better ripper than EAC. Certainly more user friendly. And the dbpoweramp creator also created AccurateRip database.
          • stevesound
            • Aug 2018
            • 9
            Hi All, Is there any way to check if my Buffalo BDXL has Read into Lead-in or Lead-out, or do I have to keep inserting disc's to get the configure Accurate rip page up?
            Steve
              • 43920
              They are two separate things, AccurateRip and read into lead in and out. To work out the latter is very difficult and involves mastering a special audio CD.
              To configure accuraterip keep feeding CDs.
              • stevesound
                • Aug 2018
                • 9
                Hi Spoon, Thanks for quick answer, sorry should have worded better, I'm just running a marker pen disc and the signs are it reads the first few tracks then starts to error so my drive may have read into lead in and out, can I assume the master disc has to match one in the database so popular disc's are best?
                Thanks Steve
                  • 43920
                  The marker pen test, this tests for c2 error pointers.
                  Yes popular discs.
                  • stevesound
                    • Aug 2018
                    • 9
                    Hi Spoon, Many thanks for the advice, having run the marker pen test it detected C2 error pointers in my drive so I set up Ultra rip with those guidelines, after feeding several disc's I did get a "This disc can be used to configure" but when I clicked OK it said it could not, do I just keep feeding more disc's until I get a OK message?
                    Thanks Steve
                      • 43920
                      Yes
