Flac files will not allow tag editing, why?
  • Tom Swaman
    • Oct 2011
    • 258
    Why will some flac files in an album that plays music apparently properly not permit tags to be edited.Click image for larger version
Name:	TAG EDITCapture.JPG
    Thanks for the assistance,
    Tom Swaman
    • 43926
    Re: Flac files will not allow tag editing, why?
    Perhaps the files are read only, or have security settings set to no write.
    • Tom Swaman
      • Oct 2011
      • 258
      Spoon,
      This drivea me crazy as the album plays and most of the files in the album can be readily edited. The files are not read only as I have checked for this. Do you have any suggestions as to what I might do so that I can edit these and not get that window popping up which I copied into my original thread post.
      Happy New Year and thank you very much,
      Tom Swaman
        • 1748
        Could you please change the file extension to .flac for a test?
        • Tom Swaman
          • Oct 2011
          • 258
          Dat Ei,
          I do not understand your comment as all of my music files have the extension of ".flac".
          Regards,
          Tom Swaman
            • 1748
            The screen shot shows the extension .fla.
              • 43926
              The short path name is shown in the error message, the real file will be .flac
              • Tom Swaman
                • Oct 2011
                • 258
                Thanks Spoon. I just wish I knew why I am not able to edit these files. I simply cannot find anything wrong with the files and I do not know what I am missing.
                Tom Swaman
                  • 1748
                  Is it possible that these files are locked by different application? Did you open those files shortly before you have tried to edit them? Did you try to edit those files after a reboot of your system?
                  • Tom Swaman
                    • Oct 2011
                    • 258
                    Dat Ei,
                    No is the answer to your question. However, I believe the locking mechanism may be an excessively long path length which blocks editing in Windows. I do not wish to state for certain as of yet, but I am leaning in this direction and I have made some major advances in my editing.
                    Tom Swaman
