Trouble converting AC3 to AAC
  • bob77
    • Mar 2017
    Hello,
    I'm trying to convert an AC3 6 channel to AAC 6 channel.
    Im getting error - DirectShow for ac3 not installed or file corrupt.
    I installed:
    dBpoweramp-Codec-DirectShow.exe
    ac3filter_2_6_0b.exe
    ac3file_0_6b.exe
    as suggested here - https://www.dbpoweramp.com/codec-central-ac3.htm
    Is my audio file really corrupt? Is there a way to make it work?
    Thank you!
    • 43926
    Re: Trouble converting AC3 to AAC
    You should be able to play the file in Windows Media Player if all installed correctly. You can?
    • bob77
      • Mar 2017
      I do not have win media player installed.
      I can play the ac3 fine in winamp or mpc-hc.
      Not sure how that relates to the installation. Maybe I didnt understand the question.
        • 43926
        The ac3 component is a directshow, that is a system wide component which is used also by Windows Media Player, the other players will not use this.
