Issue With Encoders
  • Aquatee
    • Dec 2018
    Issue With Encoders
    Hello....I just upgraded to version 16.5. I had version 14.4. I have downloaded some encoders like .wma and .aac but they are not showing up in the drop down menu when I right click to convert. Version 14.4 was a breeze to install codec and it was there. Please help!! Thank you!
    • 43901
    Re: Issue With Encoders
    You likely have R14 still installed and the codecs will be installing to the 32 bit folder, not 64 bit. Run this:
    To clear all installs of dBpoweramp then try install dBpoweramp, then codecs.
