PerfectTunes will not update tags
  • wilro15
    • Jun 2014
    • 34
    I am using the licensed version of PerfectTunes for macOS (v2.1). I'm a new user so perhaps I am being dumb, if so please forgive me.
    I am in Lists & Recommendations for Artists. PerfectTunes recommends changing an artist name which includes "feat." such as "Aeroplane feat. Au Revoir Simone" to "Aeroplane; Au Revoir Simone". So I click on the suggestion and it says "Writing Tags..."
    However the tags do not get updated if I check in another app (e.g. Kid3) or reload PerfectTunes.
    The files are marked as Read/Write for "everyone" and my own user account. File type is Apple Lossless M4A.
    • 43889
    Re: PerfectTunes will not update tags
    If you look in PerfectTUNES control center, it says it is registered?
    • Treelady
      • Sep 2019
      • 8
      Running Registered PerfectTunes 3.2 on Win 10 and tags WILL NOT SAVE. Please please help. This is maddening. Click image for larger version
      I have uninstalled, reinstalled. Shut down, rebooted.
      This always worked on Win 7.
        • 43889
        Ensure the music can be written to, where is it saved, on a NAS?
        • Treelady
          • Sep 2019
          • 8
          My library is on an internal drive that I have rights to rite to. For example dBpower amp CD Ripper writes to that drive. But the issue of not committing the tags does seem like a permissions issue.
            Super Moderator
            • 1365
            One issue at a time. Regarding the mac problem:
            Which version of Mac OS are you using? (10.15 Catalina, 10.14 Mojave or other?)
            Non-updating of tags is something the unregistered version would do - are you sure that you're not accidentally using an unregistered version from before purchasing the license? The startup window will say so: "Registration Status: Registered" or other.
            PerfectTUNES v2.1 is not the latest. Can you please try the current version - 2.3 at this time - and report if the problem persists?
