DSP Effects R6 - Playlist Writer - PLS
  • Barough
    • Apr 2005
    • 54
    Just test the new Playlist Writer and choose the PLS output, but when i checked the PLS file so did i notice that the full path is listed...
    X:\Folder\Folder\xx - Artist - Song Title.xxx
    Should it really be like that?
    When creating a M3U file so is there no full path.
    B
    • 43897
    Re: DSP Effects R6 - Playlist Writer - PLS
    It was by design, AFAIK PLS do not have the path removal of m3u, unless you can point me in the right direction.
    • Barough
      • Apr 2005
      • 54
      The software 'Music NFO Builder' have an option to create PLS files and those PLS files created by MNB don't contain the 'Full Path'. So there have to be a way to get around that, but i dont know where 2 find that info.
      • hopsta
        • Aug 2009
        • 22
        The Playlist Writer is not working for me. Could it be because I am using the Multi Encoder and had to add the Effect to all 3 encodings?
          • 43897
          Yes, it cannot be within multi-encoder.
          • hopsta
            • Aug 2009
            • 22
            If I use the new batch function, then I should be able to create playlists (haven't tried doing this yet).
            I am not sure how to attach something so I will just paste the code here:
            @ECHO OFF
            CLS
            SET batchname=CREATE-PLAYLIST.BAT
            SET version=1.0.2
            TITLE=%batchname%, Version %version%
            REM REM *blooper**blooper**blooper**blooper**blooper**bloo per**blooper**blooper**blooper**blooper**blooper** blooper**blooper**blooper**blooper**blooper**bloop er**blooper**blooper**blooper**blooper**blooper**b looper**blooper**blooper**blooper**blooper**bloope r**blooper**blooper*
            REM PLEASE CONFIGURE THESE VARIABLES
            REM Set the name of the playlist to create in each folder
            SET playlist="playlist.m3u"
            REM Create list of valid file extensions
            SET
            validExtn=.mp3.mp2.mp1.mpc.mp+.mpp.ogg.aac.mac.ape .flac.fla.wv.shn.ofr
            .ofs.ogg.m4a.mp4
            REM Add another delimiter to the end so I can search for .<ext>.
            SET validExtn=%validExtn%.
            REM Check a folder has been passed
            IF NOT EXIST %1 GOTO NoParams
            IF %~z1 GTR 0 GOTO NoParams
            REM Remove all existing "playlist.pls" files otherwise files will be
            appended
            FOR /R %1 %%G IN (%playlist%) DO IF EXIST %%G DEL "%%G"
            REM Iterate through every file and pass the path to :WriteToPlayList
            FOR /R %1 %%G IN (*.*) DO CALL :WriteToPlayList "%%G"
            GOTO:EOF
            REM
            REM WriteToPlayList : Adds the file to the playlist, if the extension
            fits
            REM : %1 The file to process
            REM
            :WriteToPlayList
            REM Check that the file extension is valid
            SET extn=%~x1
            IF [%extn%] EQU [] GOTO:EOF
            SET tmpExtn=%validExtn%
            CALL SET result=%%tmpExtn:%extn%.=%%
            REM If no match found in list of extensions exit function
            IF [%result%] EQU [%validExtn%] GOTO:EOF
            REM Escape ampersand and caret
            SET tmpString="%~dpnx1"
            SET tmpString=%tmpString:^=^^%
            SET tmpString=%tmpString:&=^^^&%
            REM Remove quotes
            SET tmpString=%tmpString:"=%
            REM Write filename to playlist
            ECHO %tmpString%>>"%~dp1\%playlist%"
            GOTO:EOF
            REM ================================================== ===
            REM NoParams : a folder has not been passed
            :NoParams
            ECHO To run this script, please pass a folder as a parameter.
            ECHO.
            ECHO Press any key to exit
            PAUSE >NUL
            REM VERSION HISTORY
            REM ===============
            REM Version Date Description
            REM 1.0.3 11/05/2010 Added full file path
            REM 1.0.2 12/07/2005 Added parameter check
            REM 1.0.1 12/07/2005 Original still had some test code in
            REM 1.0.0 12/07/2005 Initial Version
            This is a very basic batch file that will create an m3u with a list of music files in the same folder. They can be multiple files extensions, doesn't matter.
            There is one thing that I cannot get the way I want it; I would like to change the file name from "playlist.m3u" to "foldername.m3u". The problem is, when I use %~n1.m3u it uses the folder that I run the batch file with (and rightly so). Do you know of a way to change this?
              • 43897
              I am afraid batch files are not my forte.
