Multiple composers and artists not stored with ;
  • TheAndyMac
    • Aug 2016
    • 10
    I have a problem with multiple entries in composer and artist being separated with two back-slash characters "\\" i.e "Paul Statham\\P. Angel Gabriel\\Dido Armstrong" rather than using the semi-colon "; ".
    They all show correctly on screen in dbPowerAmp ripper, but when opening with Mp3tag (to tidy up some of them once ripped).
    For example see screen shots...
  • TheAndyMac
    • Aug 2016
    • 10
    Re: Multiple composers and artists not stored with ;
    Just found the Tag Manipulation "DSP" that sorts this... for anyone facing the same, just add the "ID Tag Processing" DSP and set the Manipulation option "Multiple Artists to 'Artist1; Artist2' (for non multiple artist aware programs).
    Pity I missed this earlier, but now I've found it should make ripping EVEN easier!
      • 4015
      Originally posted by TheAndyMac
      I have a problem with multiple entries in composer and artist being separated with two back-slash characters "" i.e "Paul Statham\\P. Angel Gabriel\\Dido Armstrong" rather than using the semi-colon "; ".
      This is correct. dBpoweramp and MP3Tag use different (display) separators for multi-value tags, depending on the file format. e.g. flac files in dBpoweramp, multi-value tags are separated by '; ' whereas in MP3Tag the separator is '\\'
