On one of my CD, one track keeps getting error
  • ripcd
    • Jun 2020
    • 77
    And in the folder, there the track is not found. I thought even if there was error the track would be found but it decided to not copy that track at all just because some errors were found.
    How can I adjust the settings so that it copies it anyway and instead shows how many iaccuracies are found in the track?
    • 43901
    Re: On one of my CD, one track keeps getting error
    Try ripping as burst.
    • ripcd
      • Jun 2020
      • 77
      I did that and it still came out as error for this CD.
        • 1745
        You can try to clean the CD and/or rip with a different drive. If you have no luck, accept the defective tracks or buy another copy of that CD.
          • 43901
          What is the exact error message?
          • ripcd
            • Jun 2020
            • 77
            I think it just said 'Error'
              • 43901
              At the end of ripping it should have shown a error dialog with a more detailed description.
                • 5743
                plus the log file created from the ripping should have this info. If you haven't you should set the log info to be "complete" in the CD ripper settings.
