Plextor PX230A using IDE to SATA converter
I have purchased a Plextor PX230A and hooked it up to a SATA port using a IDE to SATA converter ([URL="http://www.delock.com/produkte/F_659_IDE_61719/merkmale.html"]http://www.delock.com/produkte/F_659_IDE_61719/merkmale.html[/URL]).
When I boot up my pc, I see the light on the plextor burning and I can also see the drive from my bios (in the boot order settings).
I have sata mode AHCI on btw.
In Windows 8 however, I can't see the drive.
Does anyone have any pointers?
Re: Plextor PX230A using IDE to SATA converter
I think it is the converter which is incompatible with the drive, if the light stays on the plextor, potentially the drive has crashed internally.
The light on the drive just lights up once when I boot.
It keeps on burning after I insert a CD.
If the converter was incompatible with the drive, why does it show up in the bios as 'Plextor px230a' ?
With another significantly cheaper converter, It didn't even show up in the bios, so it appears the current converter does something.
Should I just keep trying different converters?
because the bios only gets the drive name, Windows actually tries to use the drive.
Try a USB >> IDE converter
