DSP Folder.jpg Preserve with Multi-Encoder
  • sekro
    • Jan 2015
    I can get DSP Folder.jpg Preserve to work when I use a single encode, but I've tried different configurations to make it work with the multi-encoder and none will work. I basically want to carry over the folder/cover.jpg from the source folder and copy it to ALL encode output folders. (not exporting the embedded cover, as many files I transcode don't have that).
    I tried:
    - Adding the DSP to the main Multi-encode window
    - Adding it to every single encode settings
    None work, yet when I do it one by one it works flawlessly. What am I missing?
    Possibly relevant info:
    dBpoweramp 64-bit: Release 15.1 (Registered Reference)
    DSP Effects: Release 11
    • 43923
    Re: DSP Folder.jpg Preserve with Multi-Encoder
    It is not possible, because the encoder does not have access to the source file (as it has multi-encoder in the way).
    Instead, try ID Tag Processing set to Import Folder.jpg, then ID Tag Processing on the multi-encoder set to export folder.jpg (and possibly remove that tag if you not want art embedded).
    • sekro
      • Jan 2015
      I see, that makes sense.
      Would that modify the source files?
        • 43923
        It would not.
        • sekro
          • Jan 2015
          This method would somewhat work, but there's a problem:
          In 90% of the cases I have a small (less than 500kb) embedded cover (which I wish to keep in the transcodes) and a cover.jpg (or another name) which is anywhere from 1 to 5MB.
          This method would leave me with no embedded cover art (or a huge one, not desirable), and the big cover art as cover.jpg.
          Is there a method to do what I want to do? (that doesn't require me to do each of the three encodes separately)
            • 43923
            Install the utility codec 'Update ID Tag' and convert all your files to this, with the single option set to specify the maximum size of the art.
            • sekro
              • Jan 2015
              I have tried to do it but I can't succeed.
              Here's my setup:
              On each individual encoder, one DSP, ID Tag Processing. On the tab Manipulations I have Import from: cover.jpg (left the rest untouched).
              On the multi-encoder I have one DSP, ID Tag Processing. On the Manipulations tab I have: Export to: cover.jpg
              I have tried it with files in a folder that also contains a cover.jpg, but it won't work.
                • 43923
                • sekro
                  • Jan 2015
                  Okay, that gives me the cover.jpg at the end, but it also leave it embedded.
                  If I restrict the filesize or height/width of the cover, it will export that version, and not carry over the original cover.jpg, but the compressed one.
                    • 43923
                    Use the option to delete the album art tag (this is done after exporting) and will remove the embedded art.
                    • sekro
                      • Jan 2015
                      So I guess there's no way of doing this? Shame.
                      Thanks for your help anyway.
                        • 43923
                        Yes you can:
                        So you run a 2nd 'conversion' afterwards and it reduces the size of the embedded art.
