Embedded artwork
  • 808beats
    • Dec 2017
    • 52
    Embedded artwork
    If I Batch Convert, is there any way to reduce the size of the Artwork embedded into my mp3's/FLAC rips?
    My car won't recognise any Artwork over 500 X 500, and I have a lot of files with larger Artwork.
    It would be a nightmare to do them all individually.
    TIA
    • 43919
    Re: Embedded artwork
    Include the DSP effect 'id tag processing' set a maximum art size.
    Or you can use TuneFUSION which is designed exactly for this job (syncing for cars).
    • 808beats
      • Dec 2017
      • 52
      Thanks Spoon, that DSP effect worked great.
      One slight issue I have is that when I convert from FLAC to mp3, instead of over-writing my original FLAC files, it adds the mp3 to the same Folder, so I have 2 lots of Files in the same Folder.
      I copy from my F drive to C drive first, so I don't mind if it over-writes, as the Files I'm converting are only copies.
        • 43919
        It is not deleting the flac files? you can include the DSP effect 'Delete Source files', only use this if you have the originals somewhere.
        • 808beats
          • Dec 2017
          • 52
          No, it doesn't delete them. I will add that Delete Source Files, because I only convert from copied FLACS, not from my original ones.
          Thanks for your help Spoon.
