Adding radio station manually?
  • Ralf_s
    • May 2009
    • 40
    I'm using Asset WHS 2.1 Premium with Time Radio. It works fine, but I'm missing some favorite radio stations of mine. Is there a possibility to add some manually to the Asset UPnP Server, i.e. "N-Joy" (http://ndr.ic.llnwd.net/stream/ndr_n-joy_hi_mp3)?
    Maybe someone has an idea
    Ralf
    • 43915
    Re: Adding radio station manually?
    You can create a .m3u playlist, create a new text file, add the line:
    save it, then rename the extension to .m3u and add this playlist to a folder, then in asset configuration add that folder to the library section (and set as a playlist folder).
    • AndrewD
      • Feb 2010
      This is very helpful, thanks.
      If the playlist entry points to a internet station that broadcasts a .asx file, will Asset automatically transcode to wav/mp3 if the appropriate 'force' option is set? I don't seem to be able to get this to work.
        • 43915
        No it will not.
        • Ralf_s
          • May 2009
          • 40
          Hi Spoon,
          thank you for this idea. Think this will work, but sadly I'm using the KinskyDesktop at my computer and this one doesn't support playlists of Asset UPnP or I wouldn't found them.
          Best regards,
          Ralf
          • Ralf_s
            • May 2009
            • 40
            Oh, I've forgotten to add the playlist folder as a part of the root tree. Yes it works fine. Thx
