adding extra plugin
  • radium98
    • Jul 2008
    • 30
    adding extra plugin
    Hello
    how possible to add an old plugin to the chain processing
    the plugin is called wave hummer from sonic foundry sound fxxxe.
    and what is a similar plugin to add in dbpoweramp to make the sound very loud like an orban or omnia preset , to convert my songs and play them on a cd thanks
    • 43918
    Re: adding extra plugin
    These plugins are likely only controlled in a special way, like DirectX or VST plugins.
    • radium98
      • Jul 2008
      • 30
      yes Spoon but it is the best that give a loud 0 db music ,like if it is mastered,do you suggest any other plugin to try with my preferred dbpoweramp or do you implement it in a way ?
        • 43918
        Use the DSP effect 'Dynamic Range Comrpession' followed by the DSP 'Volume normalize' set as peak to peak .
        • radium98
          • Jul 2008
          • 30
          thanks i will try that suggestion and reply back
          • radium98
            • Jul 2008
            • 30
            tried but not lowd as that plugin wave hummer :( i hope it could be a way to get it implemented one day i tried many way many vst hoster to get it work with dbpoweramp :(
