can dbpower cd ripper rip all the tracks and encode after and maybe with a spin up?
  • Drugo
    • Mar 2022
    • 40
    Hi
    can dbpower rip all the tracks and encode after and maybe with a spin up?
    really i would like to rip all tracks in wave and encode after with the ripper and have a spin up with seconds
    don't know if exact audio copy can do it (spin up and rip all tracks and after encode) ,but onter ripper can do it
    thanks
    • 5743
    Re: can dbpower cd ripper rip all the tracks and encode after and maybe with a spin u
    I'm not sure exactly what you are asking. But take a look ripping to [Multi Encoder]. Then you can set the CD ripper to rip to WAV and also other codecs (FLAC, mp3, etc.) all at the same time.
    edit: but there doesn't appear to be a way to "rip" all the tracks and delay any encoding to the very end. Encoding is done after each track.
    • Drugo
      • Mar 2022
      • 40
      hi
      i mean
      1) is there a spin up feature (for example cdex can do it) ?
      2) is there a way to rip all the cd in wave (with metadata) and after encode all the tracks (flac or ituens aac ) and delete the wave files ?
      sorry for my poor english
      thanks
      • GBrown
        • Oct 2009
        • 271
        Originally posted by Drugo
        hi
        i mean
        thanks
        Not much point in this, with the Accurate function in place. There would be no advantage to delaying the rip until after some spin up period. And converting on the fly uses multiple CPU cores so they don't affect the current rip process.
          • 43900
          CD Ripper >> Options >> CD Ripper Options >>
          Spin up Time
          We once came across a drive which would only rip accurately after reaching full speed, 99.99999% of drives do not need this option enabling
          • Drugo
            • Mar 2022
            • 40
            Spin up Time
            hi
            i haven't found this option
            thanks!
              • 43900
              You can see the option is near the end of the list.
              • Drugo
                • Mar 2022
                • 40
                hi Spoon
                thanks
