Will Image Converter Batch Convert and Reduce Size
  • mwhals
    • Jul 2015
    • 23
    If I wanted to take my 2500 x 2500 PNG files and make JPEGs that were 1000 x 1000, but keep the PNG, can Image Converter do that? Also is there a discount for one that just bought dbpoweramp V17.1 and Image Perfect latest version?
    • 43901
    Re: Will Image Converter Batch Convert and Reduce Size
    Image converter can do that, there will be a discount for Image Converter on your registered download page.
    • mwhals
      • Jul 2015
      • 23
      Thanks! I bought it and found how to copy a 2500 x 2500 PNG to a JPG 1000 x 1000.
      What I could not figure out was a way to change the name of the destination file for multiple directories. I also did not find a way to select only one file type in batch converter when there are PNG and JPG files, but only want to select *.PNG as the source.
        • 43901
        In batch converter is a filter button when choosing the files, select on jpg.
        The naming give an example source file (including folder name) and example destination file and folder.
        • mwhals
          • Jul 2015
          • 23
          Thanks. I found the filter button in the bottom left corner. I was looking elsewhere before. I am familiar with dynamic naming from using dbpoweramp ripping program extensively, but I am not sure how to dynamically code a specific file name other than the original file name.
          What I want to ultimately do is copy all of my cover.png files throughout my music directories and create folder.jpg files in the same folders. I found that I can hit F2 and change the name, but it is tedious to change 700 - 800 names. I am wondering if there is a bulk naming option when files are in different directories.
            • 43901
            You could try:
            [origpath]\folder
            as the naming
            • mwhals
              • Jul 2015
              • 23
              You could try:
              [origpath]\folder
              as the naming
              Thanks. Already had tried that and it did not work. The following popup box appears when I try that.
                • 43901
                If you run regedit, and browse to:
                HKEY_CURRENT_USER\SOFTWARE\Illustrate\dBpowerampIm age\dMCCodec
                Then for JPEG
                set the DMCDynamicNaming item directly:
                [origpath]\Folder
                • mwhals
                  • Jul 2015
                  • 23
                  Then for JPEG
                  [origpath]\Folder
                  Thanks. I will try it. I assume I need to change it back in the registry afterward? I won't want everything I ever do always name it Folder.jpg. Just the music directories.
                    • 43901
                    You can change it in the program back later.
                    • mwhals
                      • Jul 2015
                      • 23
                      Thanks. I made the change and it worked. I guess next time I will have to do it again in the registry. If I select a different dynamic naming for a following conversion to jpg, the Folder option in the registry is changed to what is used in the following conversion. Maybe, it is better in the future if I want to copy cover.png to a jpg, just let it go to cover.jpg and use a name changer to change all cover.jpg to folder.jpg. I think that is simpler.
                      • sahrenity
                        • Aug 2020
                        Thank's for this recommendation.
