Can't Access DSD downloads in ID Tags
  • Lucky Larue
    • Aug 2015
    • 63
    I purchased three DSD downloads recently and want to access them through ID Tags. When I try to do so, nothing happens. I have the latest dbpoweramp update. R.70 or something like that, I believe. Can anyone help? Thanks
  • Lucky Larue
    • Aug 2015
    • 63
    Re: Can't Access DSD downloads in ID Tags
    No replies so far, so let me clarify. I want to edit the albums' metadata in Perfect Tunes, but it doesn't seem to recognize the DSD albums. Usually when I select a specific album, all of the metadata shows up to the right where I can edit it. But this doesn't happen with these DSD albums. Can anyone explain why and if it can be fixed to do so.
      • 43900
      What file extension do these tracks have?
      • Lucky Larue
        • Aug 2015
        • 63
        Where would I find these?
          • 5743
          look in your computer's file explorer. For example, flac files have a .flac extension, mp3 files have an .mp3 extension, text files have a .txt extension.
          • Lucky Larue
            • Aug 2015
            • 63
            .dsf
              • 43900
              If you browse to the tracks through 'Browse by File and Folder' you can see the files to tag?
              • Lucky Larue
                • Aug 2015
                • 63
                Yes, I see the files there, but when I select them, nothing happens.
                  • 43900
                  Using Windows or OS X? can you take a screenshot and upload to https://imgbb.com/ and post a link here please.
                  • Lucky Larue
                    • Aug 2015
                    • 63
                    Will do.I'm using Windows 10
                      • 43900
                      Actually we have found the issue, if you have the latest dBpoweramp installed copy 'DSD SACD.dll' from
                      C:\Program Files\dBpoweramp\decoder
                      to
                      C:\Program Files\PerfectTUNES\decoder
                      • Lucky Larue
                        • Aug 2015
                        • 63
                        • Lucky Larue
                          • Aug 2015
                          • 63
                          Is this what you're needing,Spoon?
                            • 43900
                            See my message 2 back where I ask you to replace the dll file.
                            • Lucky Larue
                              • Aug 2015
                              • 63
                              Thank you. I don't know how I missed that post.
