Applying replaygain vs volume normalisation
  • Partha
    • Nov 2017
    • 158
    what is the difference?
    If i take a batch of files, first put replaygain tags and then apply replaygain, is it any different from using the volume normalisation dsp?
    Also, like replaygain has the 'album gain' option, why is there nothing similar for volume normalisation? Is volume normalisation same as applying replaygain (track gain)?
    I am only interested in normalisation or applying replaygain, since my player does not read replay gain tags. So which one?
    I understand the original files are altered, but is there some sort of compression involved too in both of these two processes?
    • 43923
    Re: Applying replaygain vs volume normalisation
    They have the same result.
    • Partha
      • Nov 2017
      • 158
      Thanks. Just need one help: Would you recommend using the equaliser dsp while ripping, both in foobar and dbpoweramp? I have ripped some elvis using the feature in foobar 2000, and it seems some of the echo and reverb in elvis' voice in the recordings is missing...
        • 43923
        I would not recommend using equalizer.
        • Partha
          • Nov 2017
          • 158
          Thanks a ton
          • Partha
            • Nov 2017
            • 158
            How do I apply replaygain to pre-existing lossy files, like MP3 from google store, without transcoding?
              • 5744
              You can't. To apply the gain, the audio will have to be re-written. Applying the gain to lossless files will also make those no longer lossless. Best approach if one needs files with RG gain applied is to keep the orginal files as an archive and create a separate set of files with gain applied.
