"unable to write ID Tags for" F:\...
  • linndex
    • Aug 2011
    • 15
    I recently changed computer (from Vista to 7) and have now problems editing ID Tags. Have the message as the thread title suggests. I had no problems before editing ID tags.
    /Joakim
    • 43915
    Re: "unable to write ID Tags for" F:\...
    Perhaps the computer only has read access to the files?
    • linndex
      • Aug 2011
      • 15
      maybe - is there any way to allow editing?
        • 43915
        It depends on your system, f might be a network drive, or a drive which was in the old computer (and the access rights of the files, the ownership are still for the old computer).
        • linndex
          • Aug 2011
          • 15
          OK, that makes sense... could I configure the external harddrive F: so I can change access rights to the new computer?
            • 43915
            You would have to research this, we cannot advise if not actually 'there', as I would not want you to loose all your files...
            • linndex
              • Aug 2011
              • 15
              Isn't there some setting in the software allowing editing permissions to the files? This should be a common problem, since all people change computers now and then.
                • 43915
                It is not our software that has these settings, rather Windows Explorer and the security tab.
