Products            Purchase            Codec Central            Forum & Support            Professional            About
Results 1 to 6 of 6
Thread: dB power amp vs Exact audio copy
  1. #1
    Join Date
    Jan 2005
    is dBpower amp as good as Exact audio copy at extracting perfect files?
    and does it re-read files and compair the results to see if they are the same.... just like exact audio copy
    EAC site - http://www.exactaudiocopy.de/
    im just wondering cos i always use dbpoweramp to rip CDs
  2. #2
    Moderator and Mover LtData's Avatar
    Join Date
    May 2004
    Location
    WV
    Re: dB power amp vs Exact audio copy
    Quote Originally Posted by Qwaz
    EAC is normally your best best for hard-to-rip CDs, but use AccurateRip to see if some of your CDs ripped properly: http://www.accuraterip.com
  3. #3
    dBpoweramp Guru neilthecellist's Avatar
    Join Date
    Dec 2004
    Location
    San Diego, California
    http://www.accuraterip.com/software.htm
    on that page, it says that Exact Audio Copy uses AccurateRip too....um, so wouldn't both be the same??
  4. #4
    Join Date
    May 2004
    Location
    WV
    Quote Originally Posted by neilthecellist
    Yes and no. Yes they both use AccurateRip, but dMC will usually rip faster. Also, I find CDGrab easier to use than EAC.
  5. #5
    dBpowerAMP Fan Wayne's Avatar
    Join Date
    Aug 2002
    Location
    Lowestoft, England
    Also EAC will not use AccurateRip with some of its ripping options. I would only use EAC if I came across a CD that dMC couldn't handle.
    Wayne
  6. #6
    Join Date
    Dec 2004
    Location
    makes sense.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Copyright 2014 Illustrate. All Rights Reserved.
