Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 84
Thread: Enhanced AACPlus (AACPlus v2) Codec
  1. #31
    Join Date
    Sep 2005
    Re: Playing the aacPlus files in Winamp 5
    Quote Originally Posted by Catrio
    Hi to everyone, Winamp is not capable for playing AAC files whit the `Plusī enhancements because the files created for this codec be inside the MP4 container
    Use this decoder
  2. #32
    Join Date
    Sep 2004
    Re: Enhanced AACPlus (AACPlus v2) Codec
    Quote Originally Posted by ckjnigel
    And Windows Media Player plays bsiegel AACplus files with the 3ivx codecs installed.
    Not on my system, I'm afraid. Any suggestions as to what to look for to solve this, please? The encoded files come out with an .mp4 extension. They play fine in Winamp (with the AudioCoding.com plugin) and in XMPlay (with the Mares plugin), but not in WMP or MPC. I have v.D4 4.5.1 of the 3ivxPro decoder installed, from the K-Lite codec pack. Many thanks.
  3. #33
    dBpoweramp Guru LtData's Avatar
    Join Date
    May 2004
    Location
    USA
    The player you use has to support AACPlus I would say, otherwise it just plays as a low-bitrate AAC file or not at all.
  4. #34
    Join Date
    Sep 2004
    Quote Originally Posted by LtData
    Sure, but bsiegel says in his introductory notes that the encoded files should play in WMP, and ckjnigel confirms that they do on his system with the 3ivx codecs installed. Although I must say that until I read these statements I wouldn't have expected WMP to play AAC+ files.
  5. #35
    dBpoweramp Enthusiast gameplaya15143's Avatar
    Join Date
    Sep 2005
    i love free stuff :D but it seems to have 'pops' during playback
    i use winamp to play it, i can use directshow players thanks to coreaac and the haali media splitter
    i used to have 3ivx installed, but it liked to notify me when ever i opened something in a directshow player that the encoder trial was up.. way to annoying for me
  6. #36
    Join Date
    Sep 2004
    An update: the encoded files will play in WMP after all, after installing a different set of codecs.
  7. #37
    Join Date
    Oct 2005
    It is possible to encode in bitrate 96kb/s?
  8. #38
    Join Date
    Sep 2005
    give it a try.. add
    96 kbit/s stereo
    96000 s
    to options.txt, maybe it will work, i dont know
  9. #39
    Join Date
    Nov 2005
    The Enhanced AACPlus encoder will work only up to 64kbps, no higher. I'm unsure as to why, since I'm almost sure that higher bitrates were created, especially since it supports surround-sound.
    Profressional version only, perhaps?
    Chris
    edit:: Winamp's free AACPlus encoder will encode to 128kbps. What's up with that?
  10. #40
    Join Date
    Nov 2005
    Hi BSiegel,
    is it possible to add stdin stdout support to your encoder?
    thank you!
  11. #41
    Join Date
    May 2004
    Location
    USA
    Doesn't AACPlus only go up to 128kbps? Higher than that, your probably better off using normal AAC
  12. #42
    Join Date
    Sep 2005
    in my opinion, from 96kbps and up, use LC aac
  13. #43
    Join Date
    Sep 2004
    bsiegel - what's the future for your codec, please? Will you be finalising it and submitting it for inclusion in Codec Central? Many thanks.
  14. #44
    Join Date
    Apr 2002
    If it has left beta, we can include a link from codec central.
  15. #45
    Join Date
    Dec 2005
    Anything new here? I would love to see this included in Codec Central, as it works perfectly for me. Needs a pretty installer though :D
Posting Permissions
  • You may not post replies
  • You may not edit your posts
