Only White Noise
  • Andybgm
    • Sep 2014
    Only White Noise
    Whatever I try to convert to flac - .wav or from cd - there is only white noise...
    Using a registered 15.1 release
    thanks for help, andy
    • 43898
    Re: Only White Noise
    Rip a CD to wave, no dsp effects then play the wave file in Windows media player. Does it have noise?
    • Andybgm
      • Sep 2014
      rip to .wav: No white noise, sounds good...
      Tried to rip to flac - normal sound...
      but why? and why now? and how long? is there any explanation?
        • 43898
        Now convert the wave which plays well, to flac, does it play ok?
        It could be the player which is at fault, there were versions of VLC which could not play flac, make sure you are on the latest software.
