I recently upgraded to 15.1 (64-bit) from 14 (32-bit), and it appears the install left most of the old files intact. I'd like to remove the old files, and only have 15.1, but I know with some software you can get burned removing earlier versions after installing a later, as there may be dependencies.
What is the best way to do this? I'm thinking uninstall all, and only put 15.1/64-bit, but will this work, or are there dependencies on the old files?
Spoon documented scenarios where 32-bit is needed (e.g. CD Writer I believe), but those are not applicable to me.
