NOTE: Any posts to this forum on or after 16th April will disappear in few days when we transition to a new forum
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Bug? Exact Audio Copy works where dbpoweramp doesn't?
  1. #1
    Join Date
    Jun 2014
    Question Bug? Exact Audio Copy works where dbpoweramp doesn't?
    I encountered a strange problem where the last two tracks of a certain music CD (Deleted Scenes From the Cutting Room Floor/Caro Emerald) will not be ripped without errors in dBpoweramp.
    Secure Ripping results in an error where the ripping is aborted due to thousands of frames needing to be re-ripped. Insecure/Burst ripping produces a file with seriously garbled sound; imagine not clicks or hisses but constant wild "jumping" like an old vinyl LP player for the last minute of the song or so. Painful to listen to...
    I have two drives for reading audio CDs, tried both with the same result. Then tried the CD in my hifi CD player with no problems. Then I tried ripping with EAC which I actually left some time ago in favor of dBpoweramp. EAC ripped both tracks without hiccups and they sound fine (no immediately audible errors that is). Even says they are accurate (certainty 200).
    Now EAC is quite old, doesn't even recognize my second/newer drive and I think dBpoweramp's interface is way better. I wonder what makes it impossible for dBpoweramp to rip these last two tracks, even inaccurately?
  2. #2
    Join Date
    Apr 2002
    Re: Bug? Exact Audio Copy works where dbpoweramp doesn't?
    Try to disable c2 pointers. If the drives are giving phantom errors with it enabled, then disable.
  3. #3
    Join Date
    Jun 2014
    Just looked, C2 Error Pointers were not enabled.
  4. #4
    Join Date
    Apr 2002
    The rest of the tracks verify with AccurateRip but the last 2 in EAC does not?
  5. #5
    Join Date
    Jun 2014
    I only ripped the last two tracks of the CD with EAC since the others were ok when ripped with dBpoweramp.
    It seems like the CD was not found in the AccurateRip database by dBpoweramp so no verification as far as I can tell. dBpoweramp did an "ultra secure" rip which worked fine for all but the last two tracks.
    EAC's interface is a bit cryptic to me so I am not exactly sure what is going on there with the AccurateRip verification. But it said "(confidence 200)", so to me it looks like EAC's AccurateRip plugin was able to find the tracks in the database and do an accurate rip where dBpoweramp failed on both accounts?
    Would you like me to retry the rip to provide more information? And what information would you need to assess the problem properly? Screenshots, settings, logfiles...?
  6. #6
    Join Date
    Apr 2002
    If you enable the secure ripping log and rip the last 2 tracks in dBpoweramp and EAC, then post the logs.
  7. #7
    Join Date
    Jun 2014
    This is the content of the log file after ripping the last two tracks:
    dBpoweramp Release 15 Digital Audio Extraction Log from Montag, 30. Juni 2014 09:05
    Drive & Settings
    Ripping with drive 'G: [ATAPI - iHOS104 ]', Drive offset: 696, Overread Lead-in/out: No
    Ultra:: Vary Drive Speed: No, Min Passes: 2, Max Passes: 4, Finish After Clean Passes: 2
    Encoder: FLAC -compression-level-8
    DSP Effects / Actions: -dspeffect1="ReplayGain=-albummode={qt}0{qt} -r128 -r128lufs={qt}-23{qt}" -dspeffect2="HDCD="
    Extraction Log
    Track 11: Ripped LBA 176842 to 193787 (3:45) in 0:50. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\11 Caro Emerald - A Night Like This.flac
    Insecure [Pass 1 & 2, Ultra 1 to 2, Re-Rip 16917 Frames]
    ** Aborted: Have to ReRip 16917 Frames, Re-Rip Limit Set to 100 Frames
    Track 12: Ripped LBA 193787 to 210100 (3:37) in 2:39. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\12 Caro Emerald - The Lipstick On His Collar.flac
    Insecure [Pass 1 & 2, Ultra 1 to 4, Re-Rip 16312 Frames]
    ** Aborted: Have to ReRip 16312 Frames, Re-Rip Limit Set to 100 Frames
    2 Tracks Ripped Inaccurately
    When you listen to the ripped tracks, both are severely distorted, like skipping on a bad CD.
  8. #8
    Join Date
    Jun 2014
    This is the log from EAC for the same tracks (different drive because EAC does not recognise the BD-ROM drive):
    Exact Audio Copy V1.0 beta 3 from 29. August 2011
    EAC extraction logfile from 30. June 2014, 9:31
    Caro Emerald / Deleted Scenes From The Cutting Room Floor
    Used drive : HL-DT-STDVDRAM GH24NS90 Adapter: 0 ID: 0
    Read mode : Secure
    Utilize accurate stream : Yes
    Defeat audio cache : No
    Make use of C2 pointers : No
    Read offset correction : 6
    Overread into Lead-In and Lead-Out : No
    Fill up missing offset samples with silence : Yes
    Delete leading and trailing silent blocks : No
    Null samples used in CRC calculations : Yes
    Used interface : Native Win32 interface for Win NT & 2000
    Gap handling : Not detected, thus appended to previous track
    Used output format : User Defined Encoder
    Selected bitrate : 768 kBit/s
    Quality : High
    Add ID3 tag : No
    Command line compressor : C:\Program Files (x86)\Exact Audio Copy\FLAC\FLAC.EXE
    Additional command line options : -6 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "BAND=%albuminterpret%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" %hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
    TOC of the extracted CD
    Track | Start | Length | Start sector | End sector
    1 | 0:00.00 | 3:50.52 | 0 | 17301
    2 | 3:50.52 | 4:00.64 | 17302 | 35365
    3 | 7:51.41 | 3:28.47 | 35366 | 51012
    4 | 11:20.13 | 3:52.61 | 51013 | 68473
    5 | 15:12.74 | 5:33.17 | 68474 | 93465
    6 | 20:46.16 | 2:45.52 | 93466 | 105892
    7 | 23:31.68 | 3:53.63 | 105893 | 123430
    8 | 27:25.56 | 3:01.73 | 123431 | 137078
    9 | 30:27.54 | 4:33.01 | 137079 | 157554
    10 | 35:00.55 | 4:17.12 | 157555 | 176841
    11 | 39:17.67 | 3:45.70 | 176842 | 193786
    12 | 43:03.62 | 3:37.38 | 193787 | 210099
    Track 11
    Filename H:\Musik\11 A Night Like This.wav
    Peak level 98.0 %
    Extraction speed 3.2 X
    Track quality 100.0 %
    Copy CRC 79465514
    Accurately ripped (confidence 200) [0DE4CB73] (AR v2)
    Copy OK
    Track 12
    Filename H:\Musik\12 The Lipstick On His Collar Doesn't Seem To Match Mine.wav
    Peak level 98.8 %
    Extraction speed 3.5 X
    Copy CRC 8573C715
    Accurately ripped (confidence 200) [816894E0] (AR v2)
    Copy OK
    All tracks accurately ripped
    No errors occurred
    End of status report
    As opposed to the dBpoweramp rip there are no audible problems with the ripped tracks.
  9. #9
    Join Date
    Jun 2014
    log from dBpoweramp using the DVD-RAM drive:
    dBpoweramp Release 15 Digital Audio Extraction Log from Montag, 30. Juni 2014 09:38
    Drive & Settings
    Ripping with drive 'I: [HL-DT-ST - DVDRAM GH24NS90 ]', Drive offset: 6, Overread Lead-in/out: No
    Extraction Log
    Track 11: Ripped LBA 176842 to 193787 (3:45) in 2:32. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\11 Caro Emerald - A Night Like This.flac
    Insecure [Pass 1 & 2, Ultra 1 to 4, Re-Rip 8428 Frames]
    ** Aborted: Have to ReRip 8428 Frames, Re-Rip Limit Set to 100 Frames
    Track 12: Ripped LBA 193787 to 210100 (3:37) in 3:21. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\12 Caro Emerald - The Lipstick On His Collar.flac
    Insecure [Pass 1 & 2, Ultra 1 to 4, Re-Rip 153 Frames]
    ** Aborted: Have to ReRip 153 Frames, Re-Rip Limit Set to 100 Frames
    Again, the resulting files sound heavily distorted.
  10. #10
    Join Date
    Jun 2014
    A rip with dBpoweramp and ripping method "burst" also results in audibly distorted files.
  11. #11
    Join Date
    Apr 2002
    It is very strange, the EAC log indicates a 100% quality, this means nothing was re-read, the data was correct as it came off the drive. However if you switch to burst mode in dBpoweramp that should be the same.
    As a test in CD Ripper >> Options >> Communication to Windows Internal (for limited accounts).
  12. #12
    Join Date
    Jun 2014
    Sorry for the delay, I was on holiday for ten days
    The ripping result after switching to communication method "windows internal" (and restarting the program) seems to be the same:
    Error ripping to FLAC, 'Track 11' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\11 Caro Emerald - A Night Like This.flac'
    Unable to read CD, check CD disc (frame LBA 191585 ripping 26 frames track end LBA 193787) [clRipperSecure::Rip]
    Error ripping to FLAC, 'Track 12' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\12 Caro Emerald - The Lipstick On His Collar.flac'
    Unable to read CD, check CD disc (frame LBA 193788 ripping 26 frames track end LBA 210100) [clRipperSecure::Rip]
    Information ripping to FLAC, 'Track 1' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\01 Caro Emerald - That Man.flac'
    Track 1: Ripped LBA 0 to 17302 (3:50) in 0:39. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\01 Caro Emerald - That Man.flac
    AccurateRip: Accurate (confidence 200) [Pass 1]
    CRC32: BCD6086C AccurateRip CRC: 7E12D06C (CRCv2) [DiscID: 012-0014e8c4-00c320af-9f0af10c-1]
    AccurateRip Verified Confidence 200 [CRCv2 7e12d06c]
    AccurateRip Verified Confidence 112 [CRCv1 2ea12c3c]
    AccurateRip Verified Confidence 200 [CRCv2 460b549d], Using Pressing Offset +12
    AccurateRip Verified Confidence 75 [CRCv1 fa26cbdc], Using Pressing Offset +12
    Information ripping to FLAC, 'Track 2' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\02 Caro Emerald - Just One Dance.flac'
    Track 2: Ripped LBA 17302 to 35366 (4:00) in 0:16. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\02 Caro Emerald - Just One Dance.flac
    CRC32: 012DCE04 AccurateRip CRC: FEC0BE88 (CRCv2) [DiscID: 012-0014e8c4-00c320af-9f0af10c-2]
    AccurateRip Verified Confidence 200 [CRCv2 fec0be88]
    AccurateRip Verified Confidence 110 [CRCv1 4d0bfe27]
    AccurateRip Verified Confidence 200 [CRCv2 eabe9661], Using Pressing Offset +12
    AccurateRip Verified Confidence 76 [CRCv1 3cbc2557], Using Pressing Offset +12
    Information ripping to FLAC, 'Track 3' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\03 Caro Emerald - Riviera Life.flac'
    Track 3: Ripped LBA 35366 to 51013 (3:28) in 0:13. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\03 Caro Emerald - Riviera Life.flac
    CRC32: B08D8907 AccurateRip CRC: 69810DD1 (CRCv2) [DiscID: 012-0014e8c4-00c320af-9f0af10c-3]
    AccurateRip Verified Confidence 200 [CRCv2 69810dd1]
    AccurateRip Verified Confidence 112 [CRCv1 4c5ac2a9]
    AccurateRip Verified Confidence 200 [CRCv2 d468ef01], Using Pressing Offset +12
    AccurateRip Verified Confidence 76 [CRCv1 ba901a05], Using Pressing Offset +12
    Information ripping to FLAC, 'Track 4' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\04 Caro Emerald - Back It Up.flac'
    Track 4: Ripped LBA 51013 to 68474 (3:52) in 0:13. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\04 Caro Emerald - Back It Up.flac
    CRC32: 010720F6 AccurateRip CRC: 3CFD5D7D (CRCv2) [DiscID: 012-0014e8c4-00c320af-9f0af10c-4]
    AccurateRip Verified Confidence 200 [CRCv2 3cfd5d7d]
    AccurateRip Verified Confidence 113 [CRCv1 efe955df]
    AccurateRip Verified Confidence 200 [CRCv2 f05152bf], Using Pressing Offset +12
    AccurateRip Verified Confidence 76 [CRCv1 a6f3afd3], Using Pressing Offset +12
    Information ripping to FLAC, 'Track 5' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\05 Caro Emerald - The Other Woman.flac'
    Track 5: Ripped LBA 68474 to 93466 (5:33) in 0:17. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\05 Caro Emerald - The Other Woman.flac
    CRC32: A62FA76A AccurateRip CRC: 8F67B2B8 (CRCv2) [DiscID: 012-0014e8c4-00c320af-9f0af10c-5]
    AccurateRip Verified Confidence 200 [CRCv2 8f67b2b8]
    AccurateRip Verified Confidence 111 [CRCv1 db638f3a]
    AccurateRip Verified Confidence 200 [CRCv2 b8004665], Using Pressing Offset +12
    AccurateRip Verified Confidence 76 [CRCv1 936a1f2], Using Pressing Offset +12
    Information ripping to FLAC, 'Track 6' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\06 Caro Emerald - Absolutely Me.flac'
    Track 6: Ripped LBA 93466 to 105893 (2:45) in 0:08. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\06 Caro Emerald - Absolutely Me.flac
    CRC32: 66B1B461 AccurateRip CRC: 30E73B91 (CRCv2) [DiscID: 012-0014e8c4-00c320af-9f0af10c-6]
    AccurateRip Verified Confidence 200 [CRCv2 30e73b91]
    AccurateRip Verified Confidence 111 [CRCv1 5872ec01]
    AccurateRip Verified Confidence 200 [CRCv2 c0db4092], Using Pressing Offset +12
    AccurateRip Verified Confidence 76 [CRCv1 e9a3c443], Using Pressing Offset +12
    Information ripping to FLAC, 'Track 7' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\07 Caro Emerald - You Don't Love Me.flac'
    Track 7: Ripped LBA 105893 to 123431 (3:53) in 0:11. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\07 Caro Emerald - You Don't Love Me.flac
    CRC32: FD2C7615 AccurateRip CRC: BCBB31E7 (CRCv2) [DiscID: 012-0014e8c4-00c320af-9f0af10c-7]
    AccurateRip Verified Confidence 200 [CRCv2 bcbb31e7]
    AccurateRip Verified Confidence 111 [CRCv1 588283ed]
    AccurateRip Verified Confidence 200 [CRCv2 20de1d25], Using Pressing Offset +12
    AccurateRip Verified Confidence 76 [CRCv1 c04f6ddb], Using Pressing Offset +12
    Information ripping to FLAC, 'Track 8' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\08 Caro Emerald - Dr. Wanna Do.flac'
    Track 8: Ripped LBA 123431 to 137079 (3:01) in 0:08. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\08 Caro Emerald - Dr. Wanna Do.flac
    CRC32: 78A00264 AccurateRip CRC: E01A444F (CRCv2) [DiscID: 012-0014e8c4-00c320af-9f0af10c-8]
    AccurateRip Verified Confidence 200 [CRCv2 e01a444f]
    AccurateRip Verified Confidence 111 [CRCv1 6eb1ca21]
    AccurateRip Verified Confidence 200 [CRCv2 dc447fcf], Using Pressing Offset +12
    AccurateRip Verified Confidence 75 [CRCv1 6db12589], Using Pressing Offset +12
    Information ripping to FLAC, 'Track 9' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\09 Caro Emerald - Stuck.flac'
    Track 9: Ripped LBA 137079 to 157555 (4:33) in 0:12. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\09 Caro Emerald - Stuck.flac
    CRC32: 33116F28 AccurateRip CRC: 2186D771 (CRCv2) [DiscID: 012-0014e8c4-00c320af-9f0af10c-9]
    AccurateRip Verified Confidence 200 [CRCv2 2186d771]
    AccurateRip Verified Confidence 112 [CRCv1 d9c15024]
    AccurateRip Verified Confidence 200 [CRCv2 e8fafeab], Using Pressing Offset +12
    AccurateRip Verified Confidence 76 [CRCv1 a5664e80], Using Pressing Offset +12
    Information ripping to FLAC, 'Track 10' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\10 Caro Emerald - I Know That He's Mine.flac'
    Track 10: Ripped LBA 157555 to 176842 (4:17) in 0:10. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\10 Caro Emerald - I Know That He's Mine.flac
    CRC32: C61E0E42 AccurateRip CRC: 9A55FF3D (CRCv2) [DiscID: 012-0014e8c4-00c320af-9f0af10c-10]
    AccurateRip Verified Confidence 200 [CRCv2 9a55ff3d]
    AccurateRip Verified Confidence 111 [CRCv1 612598aa]
    AccurateRip Verified Confidence 200 [CRCv2 d4f4e404], Using Pressing Offset +12
    AccurateRip Verified Confidence 76 [CRCv1 9fcbf80a], Using Pressing Offset +12
    Information ripping to FLAC, 'Track 11' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\11 Caro Emerald - A Night Like This.flac'
    Track 11: ERROR Ripping LBA 176842 to 193787 (3:45) in 0:32. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\11 Caro Emerald - A Night Like This.flac
    Silence detected, ReplayGain track tag not generated [clDSP::EndConversion]
    Information ripping to FLAC, 'Track 12' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\12 Caro Emerald - The Lipstick On His Collar.flac'
    Track 12: ERROR Ripping LBA 193787 to 210100 (3:37) in 0:36. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\12 Caro Emerald - The Lipstick On His Collar.flac
    dBpoweramp Release 15 Digital Audio Extraction Log from Dienstag, 15. Juli 2014 12:00
    Drive & Settings
    Extraction Log
    12 Tracks Ripped: 10 Accurate, 2 Could Not Be Ripped
  13. #13
    Join Date
    Apr 2002
    This is the CD drive which is refusing to supply data.
    There are many different ways of requesting data (such as LBA addressed, or MSF addressed), dBpoweramp requests one way and eac the other, both are 100% correct, but if the drive had a bug in its firmware, or there SCSI filter installed on the system which is causing issues (such as dvd decryption, or virtual drive).
  14. #14
    Join Date
    Jun 2014
    Just did another two rips with the second drive that is installed on my system (still with communication method "windows internal"). In both rips the last three tracks came out erroneous. But the error message is slightly different from the first drive, no "unable to read CD".
    Since both drives have roughly the same problems with the disk, my guess would be that the bug is either widely spread through drive firmware (but the circumstances to make it happen are quite uncommon) or it is indeed something to do with my system.
    I have no virtual drive software installed, the only thing I can think of that maybe is capable of DVD decryption is a software called MakeMKV that I use to rip bonus DVDs, 5.1 mixes in DVD format and the like.
    Could you maybe elaborate on how to pin down SCSI filter(s) that are installed/used? I found something helpful quickly when I googled "LBA MSF addressed" to understand what you where talking about. Not so with "Windows SCSI filter" I'm afraid...
    And I guess you are unlikely to implement a second/third block addressing method?
    Some logs:
    Error ripping to FLAC, 'Track 10' to 'H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\10 Caro Emerald - I Know That He's Mine.flac'
    Track Ripped Insecurely.
    Track 1: Ripped LBA 0 to 17302 (3:50) in 0:21. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\01 Caro Emerald - That Man.flac
    Track 2: Ripped LBA 17302 to 35366 (4:00) in 0:13. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\02 Caro Emerald - Just One Dance.flac
    Track 3: Ripped LBA 35366 to 51013 (3:28) in 0:10. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\03 Caro Emerald - Riviera Life.flac
    Track 4: Ripped LBA 51013 to 68474 (3:52) in 0:10. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\04 Caro Emerald - Back It Up.flac
    Track 5: Ripped LBA 68474 to 93466 (5:33) in 0:14. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\05 Caro Emerald - The Other Woman.flac
    Track 6: Ripped LBA 93466 to 105893 (2:45) in 0:06. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\06 Caro Emerald - Absolutely Me.flac
    Track 7: Ripped LBA 105893 to 123431 (3:53) in 0:09. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\07 Caro Emerald - You Don't Love Me.flac
    Track 8: Ripped LBA 123431 to 137079 (3:01) in 0:06. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\08 Caro Emerald - Dr. Wanna Do.flac
    Track 9: Ripped LBA 137079 to 157555 (4:33) in 0:09. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\09 Caro Emerald - Stuck.flac
    ** Aborted: Have to ReRip 2718 Frames, Re-Rip Limit Set to 100 Frames
    Track 10: Ripped LBA 157555 to 176842 (4:17) in 1:51. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\10 Caro Emerald - I Know That He's Mine.flac
    Insecure [Pass 1 & 2, Ultra 1 to 4, Re-Rip 2718 Frames]
    ** Aborted: Have to ReRip 5246 Frames, Re-Rip Limit Set to 100 Frames
    Track 11: Ripped LBA 176842 to 193787 (3:45) in 2:24. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\11 Caro Emerald - A Night Like This.flac
    Insecure [Pass 1 & 2, Ultra 1 to 4, Re-Rip 5246 Frames]
    ** Aborted: Have to ReRip 2833 Frames, Re-Rip Limit Set to 100 Frames
    Track 12: Ripped LBA 193787 to 210100 (3:37) in 3:28. Filename: H:\Musik\Caro Emerald\Deleted Scenes from the Cutting Room Floor\12 Caro Emerald - The Lipstick On His Collar.flac
    Insecure [Pass 1 & 2, Ultra 1 to 4, Re-Rip 2833 Frames]
    dBpoweramp Release 15 Digital Audio Extraction Log from Mittwoch, 16. Juli 2014 12:25
    Drive & Settings
    Extraction Log
    12 Tracks Ripped: 9 Accurate, 3 Inaccurate
  15. #15
    Join Date
    Apr 2002
Posting Permissions
  • You may not post replies
  • You may not edit your posts
