Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Problems with Batch Ripper
  1. #1
    Join Date
    Mar 2011
    I set up Batch Ripper with autorip to have my server PC work as a ripping machine. It worked fine for several weeks, but since a couple of days ago the Batch Ripper has become temperamental, as is often in a state of Post-load Waiting for CD.
    A few CDs it can still rip, but even some that dBpoweramp rips easily will put it in that state.
    Is there something I could do about it?
    Thanks in advance.
  2. #2
    Join Date
    Apr 2002
    Re: Problems with Batch Ripper
    Look in Windows explorer at the CD drive, it should say it is an audio CD and display a track listing as
    Track01
    Track02
    etc
  3. #3
    Join Date
    Mar 2011
    That is what it shows in Windows Explorer, but Batch Ripper stil states Post-Load waiting for CD
  4. #4
    Join Date
    Apr 2002
    The drive letter is the same? ie same as in explorer as to what Batch Ripper is using?
  5. #5
    Join Date
    Mar 2011
    Yes, same drive letter.
  6. #6
    Join Date
    Apr 2002
    Do you have any security software?
  7. #7
    Join Date
    Mar 2011
    Just MSE, but that has been true during the entire life of this machine.
  8. #8
    Join Date
    Mar 2011
    Quote Originally Posted by ricsimas View Post
    Hi Spoon - any suggestions of next steps, please?
    Join Date
    Apr 2002
    If whilst it is waiting for CD, yet there is one inserted, if you run CD Ripper, does it show a track listing?
    Check also you not have any virtual cd software, any other anti malware programs (MSE is fine), no programs in the tray which might interact with CDs.
  10. #10
    Join Date
    Mar 2011
    The regular ripper works perfectly despite that message in the Batch ripper.
    [/quote]
    I don't think it's the case - only thing that could be vaguely related is the Intel Storage perfomance thing, but I don't think it does anything to the CD Drive. It's also been there since the beginning of this build.
  11. #11
    Join Date
    Apr 2002
    You are using Release 2 of Batch Ripper?
  12. #12
    Join Date
    Mar 2011
    I'm sure this will make me look stupid, but how can I tell?
  13. #13
    Join Date
    Apr 2002
    Run dBpoweramp Configuration.
  14. #14
    Join Date
    Mar 2011
    It's release 1.5.
  15. #15
    Join Date
    Mar 2011
    Just installed R2. Initial results were encouraging, as it started ripping the CD, but it won't end the process - it stays there "ripping" the last track forever. This is something I experienced a couple of times with R1.5 as well.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
