Need Help With MetaData
  • aor5000
    • Apr 2014
    sorry if this has been covered before.
    I need help with metadata
    I search a cd, online finds it (but its wrong)
    I correct all the data to my standards :-)
    then 2 months later I need to RE-rip the same cd. BUT dbpoweramp doesn't remember all my corrections and gives me the same wrong info online as the first time.
    It's really bugging me ... never had this trouble using Nero.
    so does anyone know how to fix this ???
    thanks in advance.
    • 43915
    Re: Need Help With MetaData
    Can I ask why you re-rip? why not rip once to lossless then is done?
    • BrodyBoy
      • Sep 2011
      • 754
      The manual changes you've made are local....they are not going to change the data you get from the online databases a couple months later. dBp does have a local cache, but it can't save every rip indefinitely.
      But I too am curious.....why are you re-ripping your albums? Is there some (bigger) issue with your original rips?
      • aor5000
        • Apr 2014
        i ripped them to mp3 last year, but after my mp3 player dying i bought a new one ... now i'm re-ripping my cds
        • aor5000
          • Apr 2014
          thanks for the info ... can i make local cache bigger? or assign a folder?
          as stated above mate, damaged mp3 ... so replacing some cds as i didn't make back ups
            • 43915
            You can make the cache bigger, however it was not designed to hold every cd in someones library, the option is meta drop menu >> Settings >> Local Cache Settings
            • aor5000
              • Apr 2014
              thanks Spoon
              will that allow me to store more of "my" cd information?
                • 43915
                Yes
                • aor5000
                  • Apr 2014
                  Yes
                  thanks so much for your help
