Manual Meta Review
  • MKR
    • Jan 2014
    Manual Meta Review
    I'm about to embark on a massive re-rip of my library (let's just say my initial rips were janky) So I built a machine for the task; Asus P8Z77V-LE/Intel 3570K/16gb RAM/6 Pioneer BDR-208DBK Bluray drives/8tb of storage/Zalman MS800.
    My initial testing has given positive results and performance has been excellent.
    The question i have is during the batch ripping process when a disc is loaded you are presented with the Manual Meta Review window. Is there a way to bypass this screen when it finds the meta data so that you don't have to click OK each time a disc is loaded?
    • 43926
    Re: Manual Meta Review
    You can disable the manual review, then the system would run fully automatically, see the meta data options page.
    • MKR
      • Jan 2014
      Thanks Spoon
      • Bernd van Hal
        • Oct 2014
        Hi, call me a dummy but i can not find the option to stop:
        problem. can somebody tell me wat to do?
        Drank a cup of coffe and looked again...... found it. Problem solved.
