Products            Purchase            Codec Central            Forum & Support            Professional            About
Results 1 to 12 of 12
Thread: Need help tagging FLAC files
  1. #1
    Join Date
    Jul 2008
    Location
    Charlotte, NC
    I've read so many forums the past few days, my head feels like it's going to explode. I got a new 1 TB external hard drive to archive my CDs, then convert to mp3 for use on portable devices and such. About every article I've read says not to use ID3 tagging on FLAC files, but to use Vorbis comments instead. Does this mean that when using the dBpowerAMP ripper under OPTIONS, where it lists the meta data, that I can't use those tags, and have to check the box that says "Disable Tag Writing"? I hope that is not the case, because I have no idea what Vorbis comments are or how to use them. Also, if you can't use ID3 tags with FLAC, why does mp3tag say it works for FLAC. I've never actually used that program, but I believe it uses ID3v2 tagging.
  2. #2
    Da Man Spoon's Avatar
    Join Date
    Apr 2002
    Re: Need help tagging FLAC files
    dBpoweramp automatically writes the correct tag type to FLAC files, nothing to set or disable.
  3. #3
    Join Date
    Jul 2008
    Location
    Charlotte, NC
    Talking Re: Need help tagging FLAC files
    Well, that's really cool. So I can tick as many of the ID tag boxes as I want (like "encoded by", "album art", "encoder settings", etc., and they will be properly embedded into the FLAC file and be retained when converted to mp3?
  4. #4
    Join Date
    Apr 2002
    Yes
  5. #5
    Join Date
    Jul 2008
    Location
    Charlotte, NC
    Spoon,
    Thanks for your time and help. Is the same true for APE files, and if so, which format do you suggest?
  6. #6
    Join Date
    Apr 2002
    Same for ape (ape v2 tags are used)
  7. #7
    dBpoweramp Enthusiast Tigerman's Avatar
    Join Date
    Mar 2005
    Location
    Radewijk, The Netherlands
    On my windows machine I prefer Flac-files.
    This because of
    - times of ape-files are not correctly read by my WhereIsIt database
    - The winamp ape decoder doesn't allow anything to do with an ape-file after it has played the file. p.e. I need to close winamp to be able to move the ape-file or retag the file
    A disadvantage of the flac-files is the tagging. Many programs use different labels for the same field. Luckily DBpoweramp can remap tags so the tagging can be optimal for the programs you use. But it needs some fiddling.
  8. #8
    Join Date
    Jul 2008
    Location
    Charlotte, NC
    Thank you.
  9. #9
    Join Date
    Jul 2008
    Location
    Charlotte, NC
    Quote Originally Posted by Tigerman View Post
    This because of
    Thanks for your response. I'm using the flac or ape encoder (probably flac) strictly for archival purposes on an exterior hard drive. I then convert them to mp3 using LAME on dB's Music Converter (so simple even I can use it, lol) to my music folder on my C drive for general listening and adding to a portable mp3 player. I've only done a few discs (10 out of around 2500) to see how it works, and the mp3s seem to be tagged well and playing properly on Media Monkey. I'm not quite sure what kind of fiddling you mean, so if you could explain....
  10. #10
    Join Date
    Mar 2005
    Location
    Quote Originally Posted by texasflood View Post
    This part is about the converter. When converting from ape to flac some labels are renamed. p.e. comment gets description. In dbpoweramp configuration it's possible to remap that so it stays comment. Otherwise some other programs (like Tag & Rename, Winamp, MP3tag) don't read the tags right out of the box.
    However I ripped a cd to flac with a comment added and to my surprise the label for comment is comment. I expected it to be description.
    Maybe it's because of a setting I have done in the past, so can somebody confirm this who hasn't remapped labels?
  11. #11
    Join Date
    Jul 2008
    Location
    Charlotte, NC
    Hey Tigerman,
    I found that mapping tool (even though I don't know how to use it). If you don't mind, take a look at another thread I have at http://forum.dbpoweramp.com/showthre...oper*post91596 and see if you can offer any assistance. Thanks.
  12. #12
    Join Date
    Oct 2010
    when i rip cd in to flac , wmp giv mi uncnown artist and album
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Copyright 2014 Illustrate. All Rights Reserved.
