Products      |      Purchase      |     Codec Central     |        Forum / Support        |     Professional     |       About
Results 1 to 9 of 9
Thread: 24-bit 96 kHz to 16-bit 44 kHz flac
  1. #1
    Hi I just wonder if it is the correct way to create 16-bits flac files from 24-bits flac files So I can burn them as CD audio
    like this
    24bit flac --> 16 bit Wav --> 16 bit flac
    I don't need to make anything else ?
    //C
  2. #2
    Da Man Spoon's Avatar
    Join Date
    Apr 2002
    Re: 24-bit 96 kHz to 16-bit 44 kHz flac
    You can go FLAC to FLAC if you use the DSP effects Bit depth and resample
  3. #3
    Join Date
    Aug 2007
    Hello,
    I want to downsample some FLAC files from 96 Khz to 48 Khz. I tried two ways to do this downsampling:
    - FLAC to FLAC conversion with the resample DSP effect
    - FLAC to WAV conversion with option Uncompressed 48 Khz and then WAV to FLAC conversion
    I noticed that the result FLAC file has a different size according to the choosen method. Is it normal?
    Thank you!
  4. #4
    Join Date
    Apr 2002
    Wav might not have all the ID Tags of the FLAC >> FLAC.
  5. #5
    LisaRCT's Avatar
    Join Date
    May 2003
    Location
    Pa. USA
    I have a related question:
    When downsampling a 24/96 flac to 16/44.1 flac, does dbPower simply truncate the last 8 bits, or does it use a more complex conversion including dither?
  6. #6
    Join Date
    Apr 2002
    Truncate, dither has yet to be re-added to R13.
  7. #7
    Join Date
    Mar 2010
    Same question as LisaRCT back in 2009 - now that we have the dither option, is it advisable to use when downsampling 24/96 to 16/44.1 flac? The dBpoweramp Music Converter DSP (bitrate) menu advises one to do so.
  8. #8
    Join Date
    Apr 2002
    Yes if you have the option, using dither going 24 bit >> 16 bit is a good option.
  9. #9
    Join Date
    Mar 2010
    Thank you Spoon. I apologize for drifting off the OP's topic, but does anyone know if Cowon's up to date firmware (specifically for their J3 model) is capable of recognizing and playing hi-definition 24 bit FLAC files?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
